MKirsch: Why Farmall 350, front end of a Farmall 350 front bolster is exact same length from rear axle housing as the 350 Utility. Yes I agree the 340 Farmall and Utility are shorter than a 350, about 3" shorter. Even at that it's only a minor fabrication to change a 350 loader to a 340.
There is much more involved changing a loader from a 6 cylinder to a 4 cylinder tractor, or vice versa than changing from a Farmall to a utility of the same model. Believe me Kirsch, I've changed two loaders from 300 Utility to a 300 Farmall. I've also changed a loader from Farmall 504 to a Farmall 560. So on Mike"s question 3" is a lot less than 6". 6" being the difference between 504 and 560.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
