Re: Painting Grill on 806
Posted by Ken T. on January 01, 2004 at 15:43:28 from (209.62.162.215):
In Reply to: Painting Grill on 806 posted by hagan on January 01, 2004 at 14:03:46:
Yes, the white screen is riveted to the cast grille framework. Before painting mine, I chiseled off the rivets to separate the screen from the casting. Then I painted the screen white and the casting red. Then I drilled out the rivets and tapped the holes and used machine screws to reassemble. Very simple.
Post A Followup
: Re: Re: Painting Grill on 806
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
