Re: Re: SM Disc Brakes -- Pinon Bearing
Posted by Dave WV on January 01, 2004 at 18:17:45 from (64.12.97.12):
In Reply to: Re: SM Disc Brakes -- Pinon Bearing posted by Haas on January 01, 2004 at 17:48:29:
The brake plate and bearing retainer,this is the plate inside clutch disc is next to, neads removed.It has a seal and o ring.Pry plate out or
screw slide hammer in threaded hole in end of pinion shaft then shaft and plate will come out togather.Pinion bearing will come out with shaft.
On a SM you can go this far without disturbing
bull gear
Post A Followup
: Re: Re: Re: SM Disc Brakes -- Pinon Bearing
