Re: Motor Mounts for a 41' H ?
Posted by justin on January 01, 2004 at 18:45:34 from (216.188.198.180):
In Reply to: Motor Mounts for a 41' H ? posted by GM on January 01, 2004 at 18:09:07:
The early mounts are what you are describing. The reason for the change to the cast iron ones is because the weight of the tractor will cause a settling effect with the rubber, and cause the starting crank (for hand start) to not align correctly.. The mounts are actually one piece (2 staped steel pieces bonded with rubber). I have a NOS Set available. The mounts can be changed to the later cast iron mounts, but that requires the changing of the frame rails also.
Post A Followup
: Re: Re: Motor Mounts for a 41' H ?
