Re: 1944 BN smokey
Posted by F-man on January 01, 2004 at 20:29:28 from (209.41.235.64):
In Reply to: 1944 BN smokey posted by Ed inN.H. on January 01, 2004 at 18:15:08:
That sounds to me like a leaky head gasket. Chemistry does not lie. White smoke is water, blue is oil and black is gas. The oil you see is probably what you sprayed in it and your smelling it burn from the exhaust pipe. Sounds like the water is getting enough pressure after it heats up to find its way into the cylinders. It doesn't take much to make a lot of smoke.
Post A Followup
: Re: Re: 1944 BN smokey
