Re: H magneto cable?
Posted by F-man on January 02, 2004 at 06:25:27 from (209.41.235.78):
In Reply to: H magneto cable? posted by Hank Walter on January 01, 2004 at 21:36:51:
Yes, there is an "ignition" switch for magneto tractors. The switch works opposite from a battery ignition tractor. On the later, you pull out to make a closed circiut and back in to open it. With mags., You pull out to open (un-ground) the mag and push in to close the circiut to ground out the mag. These swithes look identical so you need to specify what type when you go to get one. If you are not sure, a quick check with a multi-meter will tell you what you have.
Post A Followup
: Re: Re: H magneto cable?
