Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Air Pressure
Posted by ltf in nc on October 08, 1999 at 21:45:10 from (206.228.213.19):
In Reply to: Re: Re: Re: Re: Air Pressure posted by Matt on October 08, 1999 at 06:05:50:
Matt, I do not have an answer to that question. Alot has to do with tread design and weight on front of the tractor. I usually put about 30 psi in then when I am traveling on pavement I watch to see if the tire is patterning completely across the tread. If it is running only on the center section I reduce the pressure until I get uniform wear across the tires regardless of design. The dirt will scuff off quickly when on the paved road and you can see the wear pattern. Hope this helps.
Post a Followup
: Re: Re: Re: Re: Re: Re: Air Pressure
