Re: Re: DT466 in a 856
Posted by ChadS on January 02, 2004 at 09:58:50 from (66.228.96.227):
In Reply to: Re: DT466 in a 856 posted by 42FarmallH on January 02, 2004 at 09:43:51:
You need the bellhousing adapter from a Newer Hydro 186? series tractor.. I belive the hydros were like the older 1026 Hydro,, I may be off here about the design,, but the bell housing for those rear ends have the 361-407 bell housing bolt pattern, then, the plate that bolts onto the engine has the 414 and 466 block bolt pattern, along with the bellhousing pattern of the 856-1456. Hope this helps,, ChadS
Post A Followup
: Re: Re: Re: DT466 in a 856
