Re: Re: Re: Farmall 140 Questions
Posted by Haas on January 03, 2004 at 06:19:13 from (12.65.54.89):
In Reply to: Re: Re: Farmall 140 Questions posted by Kirk Affeldt on January 02, 2004 at 20:10:00:
If you have an open center two way valve, it will work as a single acting valve if one port is plugged. However, on the down cycle, the inlet from the pump will be blocked and will load the pump. This could be bad on a 140, as I don't think the pump has an internal relief valve and the pump or drive gears could be damaged. I think on a 140, the relief valve is internal to the Touch Control Unit. If your remote is piped in such a way that the relief can't function when the remote is activated you best not pipe as a one way valve. You could install a relief valve in the line from the pump to avoid over pressure and resulting excess stress on the pump system.
Post A Followup
: Re: Re: Re: Re: Farmall 140 Questions
