Re: 786 clutch , TA or both
Posted by doug@upr on January 03, 2004 at 21:18:30 from (205.188.209.82):
In Reply to: 786 clutch , TA or both posted by Tractor Tracy on January 03, 2004 at 11:34:54:
sometimes clutches will hold under low idle but high will not, also will hold when cold then when they get hot, will slip, have also seen them slip cold then hold when cold. that said, it really does not matter, since when you split your tractor to do the t.a. you usaully have to do the clutch anyway, if your flywheel is turned to far or is in need of replacing, then it is a good idea to upgrade it to the 14" clutch and flywheel
Post A Followup
: Re: Re: 786 clutch , TA or both
