Re: broken head bolt on an H
Posted by jason on January 04, 2004 at 04:50:25 from (66.103.243.34):
In Reply to: broken head bolt on an H posted by Digger on January 03, 2004 at 21:01:51:
make sure you drill all the way through the bolt that takes alot off stress of the bolt. i had a broken bolt in the same spot on a h block, drilled through it and heated it red hot just the bolt not the block put in an easy out spun right out. good luck.
Post A Followup
: Re: Re: broken head bolt on an H
