Re: Re: Re: Gauge logo's on W6
Posted by Paul in Mich on January 04, 2004 at 07:00:12 from (68.188.227.110):
In Reply to: Re: Re: Gauge logo's on W6 posted by Ed J on January 03, 2004 at 22:01:52:
Ed, It is entirely possible that your tractor could have had gauges from both generations since it was not beyond IH to do that with a lot of components in changeover years. As to the fuse mopunted in the switch box, I think that came later, but not sure what year. Maybe someone else can verify that for you. Just curious, but which gauge has the IH, and which has IHC? Oil should be IH unless it was replaced, but water could be either since if your tractor didnt have lights, it is also possible that it didnt have a water gauge from the factory, which was not uncommon for those years, and a gauge added on later. During the war and right after, there were a lot of "bare bones" tractors out there. A neighbor of ours had a 45 "H" that although had rubber tires, had no lights, or starter, or water gauge.
Post A Followup
: Re: Re: Re: Re: Gauge logo's on W6
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
