Re: proper way to weight a tricycle Farmall
Posted by CNKS on January 04, 2004 at 17:27:25 from (207.178.96.213):
In Reply to: proper way to weight a tricycle Farmall posted by Wayne M Kittler on January 04, 2004 at 16:13:28:
Put equal weights on both sides, and/or ballast in the tires. Front weights won't help with traction, and are used only to keep the front wheels on the ground. If you pull from the swinging part of the drawbar, and don't carry heavy objects on the rear that don't touch the ground, you don't need front weights. If you use a mounted sprayer, you might.
Post A Followup
: Re: Re: proper way to weight a tricycle Farmall
