Re: Re: Re: How tight should new sleeves be in the
Posted by Bob on January 05, 2004 at 05:38:17 from (66.163.134.177):
In Reply to: Re: Re: How tight should new sleeves be in the blo posted by Mickey Cook on January 05, 2004 at 04:20:03:
The lower end of wet sleeves are sealed to the block with rubber "O" rings, or square-cut rubber rings. Some engine manufacturers refer to the rubber rings for the sleeves as "O" rings, and some refer to them as packings.
I don't know what the "string" is in your kit, unless it is graphited packing for the water pump.
Post A Followup
: Re: Re: Re: Re: How tight should new sleeves be in the
