Re: 560D won't fire - suggestions?
Posted by Aces on January 05, 2004 at 12:36:43 from (67.0.36.66):
In Reply to: 560D won't fire - suggestions? posted by WhiteBear on January 05, 2004 at 11:02:09:
WB you did not say anything about the glow plugs hope you checked them when you had the injectors out. They need to get red hot on the tip and the tip should not be burnt back very much. rings would have to be bad for it not to start. Could be return line to tank, but if you are getting good fuel to injectors return should be ok.
Post A Followup
: Re: Re: 560D won't fire - suggestions?
