Re: IH 350 Steering
Posted by rebuilder on January 05, 2004 at 18:02:25 from (216.241.135.230):
In Reply to: IH 350 Steering posted by Allen Rush on January 05, 2004 at 16:16:20:
Allen; The manual/power steering units on all the early utility IH tractors are a great weak point I believe. I am actually surprised your dealer can come up with a shaft for you! Last time I checked a couple years ago, only one shaft was available for well over $600. I used to rebuild these units(as much as possible), and usually I could never keep up with the demand. Mostly because 75% of the cores and used units brought in had busted shafts or wore out worm gears. I would estimate that for every unit I rebuilt it took four other units to get the parts to do so. Many people tried welding the teeth back on to the shaft but never helped. You have to realize that when the front wheels hit a bump or stump, all that force is transfered back into the box. As far as the stud you need, I assume it is the tapered stud which follows the worm gear. I don't rebuild these units any more but I gave those duties to a new guy. Don't worry, he's got a pretty good head on his shoulders. We should be able to come up with either measurements/stud/shaft or anything else you need. try this number 1/800/248/2955 and ask for the guy who rebuilds the steering units. By the way I think the 330/340 ut steering units are the same(or closest to it) to your unit. 460 units were quite a bit different. Post back with any further questions.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
