Re: Re: Re: Farmall 504 with combine motor?
Posted by Bill on January 06, 2004 at 10:32:11 from (63.65.68.246):
In Reply to: Re: Re: Farmall 504 with combine motor? posted by Dave_Id on January 06, 2004 at 07:57:18:
Dave,
I installed a 153 combine in a Super A. It will work, but you have a few modifications. I used a 404 clutch and pressure plate. I had the flywheel machined and installed a 300 pilot bearing in the flywheel.
I then took a drive shaft out of another A just in case I messed up and cut it down to fit.
Everything went in perfect...except the air cleaner. Still have not figured that out yet since the A filter mounts on the block and the combine engine has no provision for this. I doubt if that would be the case on a 505.
I did have to raise the fuel tank and radiator a little to fit...again the 504 should not have this problem.
The extra RPM makes the A a hotrod...bet the 504 will go like crazy too.
My two cents....
Post A Followup
: Re: Re: Re: Re: Farmall 504 with combine motor?
