Farmall Tractors Discussion Board
Re: cock for sediment bowl on Farmall M
Posted by Pete-Tex on October 10, 1999 at 09:59:25 from (152.163.197.213):
In Reply to: cock for sediment bowl on Farmall M posted by Rod Hergott on October 08, 1999 at 20:25:45:
Might try removing the cock screw (unscrew cap &
handle at the same time) soak the cap with the
packing in some light oil, then replace it.
Tighten it enough to feel firm resistance as you
turn handle.
If that doesn't stop the leak you then might try
the packing that comes in those small plumbing
repair kits, wouldn't remove the old till you try
adding some new to the old first. Might save that
Post a Followup
: Re: Re: cock for sediment bowl on Farmall M
