Getting an M running again after sitting
Posted by Paul G. in Mn on January 08, 2004 at 16:05:11 from (206.147.21.254):
Ive am getting on old M this spring and it has not ran in at least 2 years if not longer. The motor is loose. Is there any precautions I should take when I look to start it. I also have a problem with water in the rear end and I know its froze is there anything I should do to keep the houseing from cracking when it starts to thaw? Also once I get the water drained is there anything I should look at or check other then adding new oil.
Post A Followup
: Re: Getting an M running again after sitting
