Re: Re: growler/ armature check
Posted by rebuilder on January 08, 2004 at 18:35:51 from (216.241.134.123):
In Reply to: Re: growler/ armature check posted by Allan on January 08, 2004 at 17:35:41:
Allan;
No, you are correct. I use a large diameter light washer to feel for shorts. Most are pretty obvious, but I have had some armatures come back after rebuild where a short showed up.I wonder whether a slight short goes undetected? Also on my tester there are continuity leads to check for shorts between the commutator(copper) and the steel. You memory serves you well. I had to teach myself how to use this when I first started rebuilding a few years ago.
Post A Followup
: Re: Re: Re: growler/ armature check
