Farmall A Fanbelt
Posted by Josh Keller on January 09, 2004 at 15:13:53 from (172.129.125.95):
I just bought a 1946 Farmall A. When I went to put it away in the shed, I found the fanbelt had tore apart. I was wondering if anyone could help me with the sizes for the correct belts. I would like to get a new belt for the fan and also for the generator. Thanks in advance.
Josh
Post A Followup
: Re: Farmall A Fanbelt
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
