Re: To Drain or not to Drain
Posted by mowerman on January 11, 2004 at 02:21:00 from (12.28.24.63):
In Reply to: To Drain or not to Drain posted by Mary Mary on January 11, 2004 at 01:57:01:
If you have antifreeze in it you need to test it with a antifreeze tester you can get at a local auto parts house. They wiil tell you how to use it if your not sure. If it test ok leave it in but always mix the antifreeze with water 50/50 or theres danger of it freezing and busting the block!!!! NEVER leave JUST water in one over the winter!!! The antifreeze will act as a rust inhibitor too help keep it from rusting inside internally. Hope this helps
Post A Followup
: Re: Re: To Drain or not to Drain
