Re: Re: Re: Injection pump on Diesil M.D
Posted by Haas on January 12, 2004 at 06:00:30 from (12.65.56.142):
In Reply to: Re: Re: Injection pump on Diesil M.D posted by John on January 11, 2004 at 18:49:47:
To fix, the pump will have to be dissassembled and seals replace. May need other work too. Probably best to have the pump rebuilt professionally, although that is expensive. As to damage, the diesel will not give as good a lubrication as the oil, so you will get more wear. If you aren't using the tractor much, if you drain an refill with oil fairly often, it will likely last a long time. Need to watch the crankcase oil level also to make sure that diesel is not leaking into it. It only takes a cup of oil to refill the injection pump, just up to the level of the petcock. My fill port is on the rear of the pump. Seems strange your fill port is on the front of the pump, as my manual shows the fill on the rear for both the IH and the Bosch pumps.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
