Re: Re: Re: Farmall 450 diesel/gas start
Posted by Corey R on January 12, 2004 at 06:08:42 from (63.241.174.129):
In Reply to: Re: Re: Farmall 450 diesel/gas start posted by John on January 09, 2004 at 14:05:04:
John,
Not sure if you will get this but I just checked the forum this morning after a couple days. What I do for checking the radiator is to make sure there is no compression being blown back into the water. On start up or when you first switch it to diesel open the radiator cap and take a look inside, do this when the tractor is cool to avoid water from boiling over, safety, etc. With a good head the water will be rolling in the radiator, if the head is cracked there will be alot of bubbling. With a good head there will be some bubbling as well because of circulation but with a cracked head it is quite noticable. Also look for oiley water if you suspect the head is cracked, this can be another indication.
Post A Followup
: Re: Re: Re: Re: Farmall 450 diesel/gas start
