Re: Farmall Super A and 16A Mower
Posted by Hugh MacKay on January 12, 2004 at 08:02:46 from (209.226.106.57):
In Reply to: Farmall Super A and 16A Mower posted by Mike@NY on January 12, 2004 at 06:50:48:
Mike: It's been awhile since I've been around a 16A mower. I'm guessing the mounting holes in the 16A are not tapered for the nut and stud combination as on your Super A, plus you have to remove them anyhow to slide the mower in place. Those nut and stud combination can be a bit troublesome to remove. I find the best way is put two nuts on one stud and lock them together, flat side to flat side. Once you remove those the mower should bolt right up same as on the A. You can also modify the mower bar lift for raising with your touch control. On the left side can run a 1/2" rod from lift shaft for mower bar between wheel and fender to the touch control rockshaft. A neighbor of mine had one of those mowers on a Super A for years 7' bar. The mower did not have hand levers for a lift. If you get hold of one of the later parts books, would probably show the changes. I just looked in 150 Years of IH and that mower was built from 1940 to 1953. I would be willing to bet most of the new ones after 1947 were for hydraulic lift. Does the shaft your hand lift moves, go right across to left side?
Home
| Forums
Today's Featured Article -
Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
