Re: Farmall Super A and 16A Mower
Posted by Hugh MacKay again on January 12, 2004 at 08:22:49 from (209.226.106.57):
In Reply to: Farmall Super A and 16A Mower posted by Mike@NY on January 12, 2004 at 06:50:48:
Mike: Another item you should check. I would be willing to bet the mowers built after the Super A came out with the new type nut and stud for mounting drawbar with open sided hole, the mowers are probably the same way.
That lift mechanism for hydraulics was also used on the semi mount mowers like 25V, 27, etc. Super C and 200 even used it on the C-28 fast hitch mower. I think the lifting mechanism was same on all those mowers for C, SC, SA, 100 and 200. Those older semi mounts all had the same hand lever lift as the 16 A or C
Post A Followup
: Re: Re: Farmall Super A and 16A Mower
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
