Re: H radiator mounting studs
Posted by Farmer Bob on January 12, 2004 at 09:22:18 from (67.5.180.76):
In Reply to: H radiator mounting studs posted by RayA on January 12, 2004 at 08:53:25:
Ray, Hopefully the "weld a nut" trick will work. If you have to take it to a machine shop to have the stud removed, then to a radiator shop to have the leaks repaired, you could easily spend as much on it as a new one would cost. Just something to consider. Several of the radiator shops in my area won't even look at these old brass radiators. EPA and lead activists have basically shut them down from using the old fashioned methods of radiator repair. Good luck with the project.//FB
Post A Followup
: Re: Re: H radiator mounting studs
