Re: Need a Little Help for a Friend !!!!!!!!!!!!!!
Posted by rustyfarmall on January 12, 2004 at 10:55:51 from (216.248.75.154):
In Reply to: Need a Little Help for a Friend !!!!!!!!!!!!!!!!!! posted by BIG JOHN on January 12, 2004 at 10:33:10:
To my knowledge, there is no such thing as oversized rings. What you might be thinking of is oversized pistons, which would be used after reboring the cylinders in a worn engine, provided that engine did not use sleeves. In the case of the Farmall C, where cylinder sleeves are used, the common method is to replace both the sleeves and the pistons, they are sold as a set. The dealer is correct.
Post A Followup
: Re: Re: Need a Little Help for a Friend !!!!!!!!!!!!!!
