Re: Farmall Super A and 16A Mower
Posted by Mike@NY on January 12, 2004 at 13:00:36 from (209.217.220.220):
In Reply to: Farmall Super A and 16A Mower posted by Mike@NY on January 12, 2004 at 06:50:48:
Thank you all for your responses. The 16A I got is from my father's '42 A, and we are fourtunate enough to have the manuals for it (thank you for offering though scotty). He has had it for 20 years, never used it (came with the tractor when he got it). It is a hand lift model, don't know exactly how it works. Right now it is outside, have to wait for spring for the snow to melt, then I want to bring it into the garage and go through it. I would like to put it on the Super A, as I have that tractor available. My '44 A is set up for cultivating. Sounds like it can be done, but working around the studs will be a trick. I need to get the mower on and off, as I plan to use the Super for more than mowing. I can use the Super A for short term, but another "A" in the future might be a good idea. It will be a good reason to get another tractor. Thank you all for your input, it will help me in deciding what I want to do.
Post A Followup
: Re: Re: Farmall Super A and 16A Mower
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
