Re: Gotta be valve guides, right?
Posted by MN Scott on March 31, 2009 at 18:31:43 from (206.9.216.46):
In Reply to: Gotta be valve guides, right? posted by Jim Isler on March 31, 2009 at 11:37:33:
90 PSI in on the low side. Did you measure your sleeves for taper and out of round? Willing to bet your new perfectally round rings are not sealing on your worn pistons and sleeves. Most of the time on a gas engine if the rings are worn your pistons and sleeves are to.
