Farmall Tractors Discussion Board
Re: Drained Red Milky fluid from differential on Super A
Posted by big fred on October 11, 1999 at 12:36:08 from (12.13.226.13):
In Reply to: Drained Red Milky fluid from differential on Super A posted by Marvin on October 11, 1999 at 10:46:08:
My guess is that the water is coming down the shifter. I don't know for sure what will prevent that, I had over a gallon of water in the trans of my B which had separated out during the time it sat outside. Keeping it under cover will help, I'm going to see if putting a tight fitting rubber washer on the shift lever under the spring helps. At least it should deflect some of the water. I also plan on keeping the tractor under a tarp or in a shed from now on when it rains.
Post a Followup
: Re: Re: Drained Red Milky fluid from differential on Super A
