Re: Re: What do you guys suggest
Posted by Wardner on January 13, 2004 at 13:14:09 from (67.24.202.136):
In Reply to: Re: What do you guys suggest posted by 26Red on January 13, 2004 at 11:03:41:
The ring and pinion out of a 560 is slower. The 560 also has a slower first gear. I put these parts in a SMTA along with the better bearings. The tractor is very slow. I need the slow speed when running a heavy bush hog on overgrown fields. It helps when tilling as well. When the TA is pulled back, top speed is probably less than 10 mph -- about the same speed as a Cub.
I saw a 560 rear frame in the YT "Photo Ads" several days ago. It is probably still there.
Post A Followup
: Re: Re: Re: What do you guys suggest
