Re: where to check trans. oil on Super C
Posted by Randy in NE on January 14, 2004 at 06:13:08 from (216.58.237.20):
In Reply to: where to check trans. oil on Super C posted by Larry B. on January 14, 2004 at 06:01:23:
It should be the same as on a C. It is on the back of the rearend just below the belt pulley. There is a square headed plug. The level should be up to that level, or reasonably close. You can add oil there or through the fill plug in the operators platform next to the clutch peddle. It has a recessed 1/2" (might be 3/8") head in it. Your 1/2" drive rachet should fit right in it. The transmission/rearend holds just under 5 gallons. Depends on if you drain the oil out of the pto housing. There is an oil slinger in the rearend that supplies oil to the pto. Most but not all of the oil will drain back into the rearend. The drain plug is located on the bottom of the housing and you need to remove the drawbar to get at it.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
