Re: Freeze plug for Super A
Posted by gene b on January 15, 2004 at 06:01:11 from (67.1.105.206):
In Reply to: Freeze plug for Super A posted by Lewis on January 14, 2004 at 15:51:56:
While you have the rear freeze plug out it would be a great time to remove the lower rad housing an clean the little holes at the bottom of the sleeves if your plug is leaking i can just see the crud in the block at least that has been my experience.I find ones from COLO and FLA seem to be the worst one even had three of the four holes so tite i had to punch out with a long piece of steel found this after the sleeves were pulled. Yopu can call 888-683-2859 if you need more info.
Post A Followup
: Re: Re: Freeze plug for Super A
