Re: need help to remove front pump on 806
Posted by Bob on January 15, 2004 at 06:37:45 from (66.163.134.177):
In Reply to: need help to remove front pump on 806 posted by Larry B. on January 15, 2004 at 05:36:20:
The 4 bolts that go all the way through the assembly to the pump should have copper washers on them, so they're easy to identify. There are 3 or 4 short bolts that hold the outer steel cover plate to the main casting that can stay in. Some units (I believe it was the lower serial numbers) had 2 more bolts, one upper rear and one lower front, that went through the outer casting, and into the steel plate sandwiched between the casting and the tractor. If you have these, and remove them, the assembly will stay together because of the pump bolts, anyway.
All the other bolts need to be removed.
Post A Followup
: Re: Re: need help to remove front pump on 806
