Re: Carb icing--but I'm almost home!
Posted by ChadS on January 15, 2004 at 19:21:04 from (66.228.96.240):
In Reply to: Carb icing--but I'm almost home! posted by Jerry in MI on January 15, 2004 at 19:12:24:
Richen the main jet adjustment, On our pullers, when pulling in cold weather, it ices up too,, it never goes completly away but richening the mixture helps reduce it. If you have to run with the choke on,, it is not getting fuel,, you may be mistaking the icing instead of the load adjustment. You might wrap the carb and intake tube with insulation to prevent icing, Hope this helps,, ChadS
Post A Followup
: Re: Re: Carb icing--but I'm almost home!
