Farmall Tractors Discussion Board
Re: CFUEL PROBLEM
Posted by Ludwig on October 11, 1999 at 18:15:44 from (209.252.186.86):
In Reply to: CFUEL PROBLEM posted by Buford on October 11, 1999 at 13:59:23:
Won't idle unless choke is "closed" meaning no choke?
Well sure...
If the choke is open you run too rich, nothing good going on.
If you mean choke on, then you got
1. carb trouble - leanin out.
2. Fuel line trouble - crud in the line makin you lean out.
3. Fuel pump problem?
Post a Followup
: Re: Re: CFUEL PROBLEM
