Re: Carb icing--but I'm almost home!
Posted by Donnie on January 15, 2004 at 22:42:24 from (68.77.204.10):
In Reply to: Carb icing--but I'm almost home! posted by Jerry in MI on January 15, 2004 at 19:12:24:
The icing up is fairly normal on the number series tractors. They put better manifolds and intakes on them to keep the fuel and air colder while going into the engine. (More hp). Like Chad said make sure it isn't running to lean. Fatten it up if you have to. It may be that it just needs to soak in some GOOD cleaner for a couple of days. If it has set for a while there could be some build up that your not seeing. Dads 300 and my 450 do it quite a bit. Hope this helps.
Post A Followup
: Re: Re: Carb icing--but I'm almost home!
