Re: Carb icing--but I'm almost home!
Posted by Bob M on January 16, 2004 at 07:02:14 from (165.170.128.66):
In Reply to: Carb icing--but I'm almost home! posted by Jerry in MI on January 15, 2004 at 19:12:24:
Sounds like there's a blockage in the carburetor main jet metering circuit. A thorough teardown (including removing the metering orifices), followed by long soak in carb cleaner then a blow out all the passages with compressed should cure the problem. As the others suggest carb icing is a normal characteristic of these tractors - even when the carburetor is working correctly. Icing seems to be worst when it's about 40 deg and 100% humidity out. Warmer and colder temperatures diminish the problem. Stuff that helps with carb icing: Obviously both carb mixture screws must be set right so you can get the choke off immediately after starting (choking seems to make icing worse). Have the right thermostat is installed and working. Use a winterfront over the grille to block airflow thru the radiator. (An old poly feed bag held in place with a couple bungees works great!). Minimize idling - put the engine under load ASAP after startup. Shut the engine off (or idle it at ½ throttle or so) if it's gonna sit unloaded more than a couple minutes. Dumping a couple bottles of fuel line de-icer in the tank sometimes helps. Make a temporary sheet metal shield to catch warm air off the radiator and direct it over the carburetor, or install a heat houser. In extreme cases you can put a flex hose on the air cleaner inlet then arrange the hose so it picks up hot air off the exhaust manifold.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
