Re: Jump Starting 6 volt with 12 volts
Posted by 49 Cubber! on January 16, 2004 at 12:38:22 from (206.74.216.88):
In Reply to: Jump Starting 6 volt with 12 volts posted by Ronald Vogt on January 16, 2004 at 12:25:02:
If your hooking it battery to battery,Im surprised you havent blown something up already.If your just hooking it to the starter post and ground,your fine!
Post A Followup
: Re: Re: Jump Starting 6 volt with 12 volts
