Re: Jump Starting 6 volt with 12 volts
Posted by Jeff on January 16, 2004 at 15:01:06 from (192.55.52.1):
In Reply to: Jump Starting 6 volt with 12 volts posted by Ronald Vogt on January 16, 2004 at 12:25:02:
I recently tried this same thing on my 6v H. The top of the battery blew off about the same time I was disconnecting the leads from the 6V battery. The 6V was new. I don't know what all I did wrong but I know I won't try it again!
Post A Followup
: Re: Re: Jump Starting 6 volt with 12 volts
