Re: Jump Starting 6 volt with 12 volts
Posted by not an idiot on January 16, 2004 at 15:48:09 from (68.51.69.246):
In Reply to: Jump Starting 6 volt with 12 volts posted by Ronald Vogt on January 16, 2004 at 12:25:02:
Is starting your tractor worth going blind, being burned by acid, or otherwise getting seriously injured when your battery explodes?
Post A Followup
: Re: Re: Jump Starting 6 volt with 12 volts
