Re: Re: Jump Starting 6 volt with 12 volts
Posted by not an idiot on January 16, 2004 at 16:00:10 from (68.51.69.246):
In Reply to: Re: Jump Starting 6 volt with 12 volts posted by Mark in AB on January 16, 2004 at 15:58:06:
With this amount of brainpower reverse should work just fine!
Post A Followup
: Re: Re: Re: Jump Starting 6 volt with 12 volts
