Re: How to tell 6 volt system or 12 w/o battery
Posted by Dan on January 16, 2004 at 20:05:50 from (12.160.160.64):
In Reply to: How to tell 6 volt system or 12 w/o battery posted by Dave on January 16, 2004 at 19:51:01:
Obvious signs are if it has been changed from generator to alternator. If it still has the generator you could see if it looks original, check the regulator same way. If it has a resistor in the line from the ignition to the coil it is probably 12 volt. The original 6 volt is positive ground, does it look like this is or not. If the distributor is hooked to the positive terminal on the coil it is positive ground.
Post A Followup
: Re: Re: How to tell 6 volt system or 12 w/o battery
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
