Re: flywheel starter ring gear
Posted by 49 Cubber! on January 17, 2004 at 08:59:21 from (206.74.216.103):
In Reply to: flywheel starter ring gear posted by Joe B. from S.C. on January 17, 2004 at 08:20:00:
Ive heard of people putting them in the oven on 500 or or and heating it up for a few hours,that is if your wife will let you.
Post A Followup
: Re: Re: flywheel starter ring gear
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
