Farmall Tractors Discussion Board
Re: **Sodium Silicate**
Posted by Martin on October 12, 1999 at 02:34:31 from (216.128.143.182):
In Reply to: **Sodium Silicate** posted by Merlin on October 11, 1999 at 14:17:46:
I have used water glass 4-5 times that I recolect, if you look on a can of k&w blockseal you will find the 2 main ingredients are sodium silicate, and fullers earth [cat litter], haven't looked at justice brothers, but amagine its the same.
I used it on a Bronco II 2.9 with alumn heads,
a 390 ford that was so bad water was comming out the tailpipe, put a piece of cardboard in front of the radiator to get it good and hot used 2 quarts on it, I kept adding water, every once in awhile it would pick up a cyl, when it left the shop it was hitting on all 8, and I saw at car run around town for 2-3 years.
Saved the best for last.. A friend loaned his super a to a nieghbor to pull tobcco wagons, had it for 2 years, Billy and I went to get it, it was out from under the shelter with nothing over the exhust, stuck like dicks hatband. Pulled it down, the block is cracked between the cyls, I told him it need a block, he said we are going to fix this one no matter what it costs. To end a long story, it fixed it, that was 7 years ago, I bought the tractor, bought another block,[its still in the storage shed,] this is a working tractor, full of antifreeze, you tell me..does it work? Will you have any problems with it? Who knows.If the vehicle has a thermostat, you need to knock the center out of it and reinstall it for awhile to let it cure.
Enough rambling for an old man for now, my forefingers are tired...
Post a Followup
: Re: Re: **Sodium Silicate**
