Re: Farmall H Rod Bearing Washers
Posted by lee on January 19, 2004 at 06:47:01 from (24.24.92.235):
In Reply to: Farmall H Rod Bearing Washers posted by Roger WI on January 17, 2004 at 20:20:57:
I would not use a split lock. Look to automotive machine shops or automotive speed shops or
anywhere you can get automotive engine grade hardware. The washers likely have a smaller OD
and a more closely sized ID to match the bolt size. They may even be ground flat and parallel as opposed to just stamped washers. They may be similar to what are referred to as automotive AN washers, but I may be mistaken. I am talking generally as I don't have direct experience with these washers as applied to the H.
Post A Followup
: Re: Re: Farmall H Rod Bearing Washers
