Re: B275 CAV fuel pump problems...help.
Posted by lee on January 19, 2004 at 10:47:40 from (24.24.92.235):
In Reply to: B275 CAV fuel pump problems...help. posted by Phil Anderson on January 19, 2004 at 08:42:18:
Here is a quick dscription of the venting procedure for an IH 354 which uses the same BD144 engine and should be similar. 1)adequate fuel, fuel shut-off fully open, engine stop control in stop position 2)loosen air vent screw at water trap until fuel free of air bubbles flows from vent screw. tighten. 3)loosen spill pipe banjo bolt at top of fuel filter canister. Use hand pump til fuel free of bubbles, tighten banjo while fuel still flowing 4)Loosen injector pump inlet pipe and use hand pump til fuel free of bubbles, tighten while fuel still flowing 5)loosen lower vent screw on injector pump body and use hand pump til fuel free of bubbles, tighten while fuel still flowing 6)loosen upper vent screw and use hand pump til fuel free of bubbles, tighten 7)turn engine 1/2 turn , bleed the lower vent screw again as above. 8)push engine stop control in to run position 9)loosen all injector unions at the injectors, move the governor lever to full open. Turn the engine with the starting motor til fuel free of bubbles from all unions, tighten unions. 10)start the engine if it runs smooth you are done. If not loosen each injector union for a few seconds, in turn, while running. This is atwo man job more or less as you need someone to hand pump it and one to loosen and tighten the vents or other connections while fuel still flowing. This well better get you going as I just spent 20 minutes typing it. If it ran before this should do it.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
