Farmall Tractors Discussion Board
Re: Remove front tires
Posted by Corky on October 12, 1999 at 07:59:32 from (63.22.8.56):
In Reply to: Remove front tires posted by Tracto Tim on October 12, 1999 at 07:40:54:
Tim all you have to do is take 2or 3 short pieces of 2x6 or so make a short ramp by fastening them togeather then drive your good tire up the ramp it will lift the tire you want to change off the ground the 4 to 6 inches you need it also works great for repacking front wheel bearings .Make sure to block the rear wheels for safety. good luck. Corky
Post a Followup
: Re: Re: Remove front tires
