Re: Odd Resistor Electrical behaviour
Posted by RB on January 19, 2004 at 19:51:25 from (65.128.72.24):
In Reply to: Odd Resistor Electrical behaviour posted by Dave Craft on January 19, 2004 at 19:11:26:
On an original 12v system the solenoid supplies 12 volts to the coil through a separate wire, not the resistor, for starting. Then when you release the button, power through the resistor from the ignition switch is cut to about 8 volts. If your 404 was originally 6 volts it may be wired wrong. In most cases like this the engine cranks but won't start until you stop cranking, then it starts while still turning from the momentim of the 12 volts. Hope this helps.
Post A Followup
: Re: Re: Odd Resistor Electrical behaviour
